Configuring GIS subsystem
All address information for online tracking and reports is taken from Gurtam Maps. The formats of the map files for Gurtam Maps are specific vector graphics files that contain a map of a specific area. This format is not editable and is intended for use in the map server of Gurtam Maps.
Gurtam Maps are created from vector maps in different formats such as MP, MapInfo, ESRI Shape, OSM (OpenStreetMap), or KML. Note that a source map should be in the WGS-84 coordinate projection in grades.
Vector maps in the closed Gurtam Maps format allow ADF-based programs to render map images, search for named elements, use geocoding, including reverse geocoding.
Limited access is possible with the maps. It means that the detailed map of some town or region can be available only to users with certain billing plan. To add such maps, forward a request to support@wialon.host
- Questions and answers
- Conversion table: polyline (PL)
- Conversion table: POI
- Conversion table: Polygon (PG)
- Gurtam Maps scale
.MP | OSM | Gurtam Maps | ||||||||
Code | Key | Value | Keys | Key_ values | Type | GM type | Data level (0-2) | Comment | Image | Icon |
0x0001 | highway | motorway | PL | 1 | 2 | A restricted access major divided highway, normally with 2 or more running lanes plus emergency hard shoulder. Equivalent to the Freeway, Autobahn, etc. | 0-4 5-9 10-12 | |||
highway | motorway_link | PL | 2 | 2 | The link roads (sliproads/ramps) leading to/from a motorway from/to a motorway or lower class highway. Normally with the same motorway restrictions. | 0-4 5-7 | ||||
0x0002 | highway | trunk | PL | 3 | 2 | Important roads that are not motorways. Typically maintained by the central, not local government. Need not necessarily be a divided highway. | 0-4 5-9 10-12 | |||
highway | trunk_link | PL | 4 | 2 | The link roads (sliproads/ramps) leading to/from a trunk road from/to a trunk road or lower class highway. | 0-4 5-7 | ||||
0x0003 | highway | primary | PL | 5 | 2 | Roads generally linking larger towns. | 0-5 6-12 | |||
highway | primary_link | PL | 6 | 2 | The link roads (sliproads/ramps) leading to/from a primary road from/to a primary road or lower class highway. | 0-5 6-7 | ||||
0x0004 | highway | secondary | PL | 7 | 2 | Roads generally linking smaller towns and villages. | 0-5 6-9 | |||
highway | secondary_link | PL | 8 | 2 | The link roads (sliproads/ramps) leading to/from a secondary road from/to a secondary road or lower class highway. | 0-5 6-7 | ||||
0x0000 | highway | tertiary | PL | 9 | 2 | Minor roads. | 0-5 6-8 | |||
highway | tertiary_link | PL | 10 | 2 | The link roads (sliproads/ramps) leading to/from a tertiary road from/to other minor roads. | 0-5 6 | ||||
0x000a | highway | unclassified | PL | 11 | 1 | Unclassified roads typically form the lowest form of the interconnecting grid network. | 0-3 4-7 | |||
0x0042 | highway | unsurfaced | PL | 12 | 1 | Unpaved roads. | 0-3 4-7 | |||
highway | track | PL | 13 | 1 | Roads for agricultural use, gravel roads in the forest etc., usually unpaved/unsealed but may occasionally apply to paved tracks as well. | |||||
0x0005 | highway | residential | PL | 14 | 1 | Roads accessing or around residential areas but which are not a classified or unclassified highway. Streets. | 0-4 5-7 | |||
0x0006 0x000b 0x0008 0x0009 0x0049 | highway | living_street | PL | 15 | 1 | A street where pedestrians have priority over cars, children can play on the street, the maximum speed is low. Sometimes called Home Zone. | 0-2 3-5 | |||
0x0007 | highway | service | PL | 16 | 1 | Generally for access to a building, motorway service station, beach, campsite, industrial estate, business park, etc. This is also commonly used for access to parking and trash collection. | 0-2 3-5 | |||
highway | bridleway | PL | 17 | 1 | Roads for horses, cartage. | |||||
highway | cycleway | PL | 18 | 1 | Cycleways for bicycles. | |||||
cycleway | lane | PL | 18 | 1 | A lane is a route for bicycles that lies within the roadway. | |||||
cycleway | track | PL | 18 | 1 | A route for bicycles that is separate from the road. | |||||
highway | footway | PL | 19 | 1 | Footpaths for pedestrians, e.g., walking tracks and gravel paths. | |||||
0x0048 0x0016 | highway | pedestrian | PL | 19 | 1 | For roads used mainly/exclusively for pedestrians/shopping areas. Also for tagging squares and plazas. | ||||
highway | bus_guideway | PL | 20 | 1 | A busway where the vehicle guided by the way (though not a railway) and is not suitable for other traffic. | 0-3 4-7 | ||||
junction | roundabout | PL | 21 | 1 | Circle movement. | 0-3 4-6 | ||||
0x0014 | railway | rail | PL | 25 | 1 | Full-sized passenger or freight trains in the standard gauge for the country or state. | ||||
railway | tram | PL | 26 | 1 | One or two carriage rail vehicles, usually sharing the motor road for trams. | |||||
0x001f | waterway | river | PL | 30 | 2 | For narrow rivers which will be rendered as a line. | ||||
0x0018 | waterway | canal | PL | 30 | 1 | An artificial open waterway used for transportation, waterpower, or irrigation. | ||||
0x0026 | waterway | stream | PL | 30 | 1 | A naturally-formed waterway that is too thin to be classed as a river. An active, able-bodied person should be able to jump over it if trees along it are not too thick. | ||||
0x0044 | waterway | drain | PL | 30 | 1 | An artificial waterway for carrying storm water or industrial discharge. | ||||
waterway | weir | PL | 30 | 1 | A barrier built across a river, sometimes to divert water for industrial purposes. Water can still flow over the top. | |||||
waterway | dam | PL | 31 | 1 | A wall built across a river or stream to impound the water. A dam normally does not have water flowing over the top of it. | |||||
aeroway | runway | PL | 35 | 1 | A strip of land kept clear and set aside for aeroplanes to take off from and land on. | |||||
0x0045 0x001d | boundary | administrative | admin_level | 8 | PL | 191 | 1 | State, county, local council. | ||
0x001c | PL | 192 | 1 | Region boundary. | ||||||
0x001e | boundary | administrative | admin_level border_type | 2 nation | PL | 193 | 2 | National boundary. |
.MP | .OSM | Gurtam Maps | ||||||
Code | Key | Value | Type | GM type | Data level | Comment | Image | Icon |
0xf201 | highway | traffic_signals | POI | 50 | 0 | Lights that control the traffic. | ||
0xf002 0x2f08 0x2f17 0xf001 0xf003 0xf004 | highway | bus_stop | POI | 51 | 0 | A small bus stop. | ||
highway | metro | POI | 500 | Metro. | ||||
highway | tram | POI | 501 | A tram stop. | ||||
0x5900 0x5901 | highway | airport | POI | 503 | Airport. | |||
0x2f03 | highway | services | POI | 52 | 0 | A service station to get food and eat something, often found at motorways. | ||
0xf007 | railway | station | POI | 53 | 0 | A railway station. | ||
0x4600 | amenity | pub | POI | 55 | 0 | A place selling beer and other alcoholic drinks; may also provide food or accommodation. | ||
0x2d02 0x2d00 | amenity | nightclub | POI | 55 | 0 | A nightclub. | ||
0x2a0e | amenity | cafe | POI | 55 | 0 | A cafe. | ||
0x4500 | amenity | restaurant | POI | 55 | 0 | A restaurant. | ||
0x2a0d | amenity | fast_food | POI | 55 | 0 | An area with several different restaurant food counters and a shared eating area. Commonly found in malls, airports, etc. | ||
0x2f0b | amenity | parking | POI | 56 | 0 | Car park or a parking. | ||
0x2f02 | amenity | car_rental | POI | 56 | 0 | A place to rent a car. | ||
amenity | taxi | POI | 56 | 0 | A place where taxis wait for passengers. | |||
0x2f01 0x4400 | amenity | fuel | POI | 57 | 0 | Petrol station, gas station, marine fuel, etc. | ||
0x2e05 | amenity | pharmacy | POI | 58 | 0 | A pharmacy. | ||
amenity | hospital | POI | 58 | 0 | A hospital. | |||
0xf001 | amenity | bus_station | POI | 60 | 0 | Bus station. | ||
0x2f06 | amenity | bank | POI | 61 | 0 | A bank. | ||
amenity | bureau_de_change | POI | 61 | 0 | Currency exchange, a place to change foreign banknotes and traveller's cheques. | |||
amenity | atm | POI | 61 | 0 | An ATM or cashpoint. | |||
0x2b00 0x2b01 0x2b02 | tourism | hotel | POI | 62 | 0 | A hotel, a motel, a guest house | ||
tourism | hostel | POI | 62 | 0 | A hostel. | |||
0x0100 | POI | 302 | Capital. | |||||
0x0200 | POI | 63 | 2 | A megalopolis over 5 million people. | ||||
0x0300 0x0400 | place | city | POI | 64 | 2 | A city of 1-5 million people (MP). | ||
0x0500 0x0600 0x0700 0x0800 0x0900 0x0a00 0x0006 0x0004 | place | town | POI | 65 | 1-2 | A town from 10 to 100 thousand people. | ||
0x0b00 0x0c00 0x0d00 0x0e00 0x0f00 0x1000 0x1100 0x0010 | place | village_greenhamlet | POI | 66 | 1 | A village below 10 thousand people. | ||
0x640a | POI | 67 | 0 | Captions. | ||||
place | continent | POI | 195 | 2 | A continent. | |||
0x6602 | place | state | POI | 196 | 2 | A state. | ||
0x1e00 | place | region | POI | 197 | 1 | A region. | ||
0x1f00 | place | country | POI | 198 | 1 | A country, area. |
Conversion table: polygon
0x0047 0x003b 0x0045 0x0049 0x0040 0x0041 | waterway | riverbank | PG | 130 | 2 | Used for large rivers, to define an area between the opposite riverbanks. | ||
divided by size | natural | water | PG | 131 | 2 | Lakes, water bodies, etc. | ||
divided by size | landuse | reservoir | PG | 131 | 2 | An artificial reservoir. | ||
0x0028 | PG | 132 | 2 | Sea, the ocean. | ||||
waterway | riverbank | PG | 133 | 2 | A large river. | |||
leisure | park | PG | 140 | 1 | A park, open green area for recreation. | |||
0x004e 0x004f 0x008e 0x0086 0x0087 0x0088 | leisure | garden | PG | 141 | 1 | A garden. | ||
0x006d | amenity | townhall | PG | 145-146 | 1 | A town hall building (mayor's office), administrative building. | 0-2 3 | |
0x001a | landuse | grave_vard | PG | 147 | 1 | A graveyard, a cemetery. | ||
0x000a | amenity | school | PG | 148 | 1 | A school. | ||
amenity | university | PG | 148 | 1 | A university. | |||
amenity | college | PG | 148 | 1 | A college. | |||
0x3002 | amenity | hospital | PG | 149 | 1 | A hospital. | ||
shop | supermarket | PG | 151 | 1 | A supermarket. | 0-2 3 | ||
tourism | camp_site | PG | 153 | 0 | Camping, a place where you can pitch a tent. | |||
tourism | caravan_site | PG | 153 | 0 | A place where you can park a caravan overnight or for longer periods. | |||
tourism | picnic_site | PG | 154 | 0 | A place where you can have an outdoor picnic. May have facilities such as tables and benches. | |||
tourism | theme_park | PG | 155 | 1 | A theme park, amusement park. | |||
tourism | attraction | PG | 156 | 0 | A general tourism attraction. | |||
tourism | zoo | PG | 157 | 1 | A zoo. | |||
tourism | artwork | PG | 158 | 1 | A tag for public pieces of art. | |||
historic | archaelogical_site | PG | 159 | 0 | Archaeological museum. | |||
0x0050 0x0081 0x0082 0x0083 0x0084 0x0085 0x0052 0x008f 0x0090 0x0091 | landuse | forest | PG | 165 | 2 | Managed forest or woodland plantation. | ||
0x0001 0x0002 0x0003 | landuse | residential | PG | 166 | 1 | Predominantly houses or apartment buildings. | 0-3 4-7 | |
landuse | retail | PG | 167 | 1 | Predominantly shops. | 0-3 4-7 | ||
landuse | commercial | PG | 168 | 1 | Predominantly office buildings, business parks, etc. | 0-3 4-7 | ||
0x000c | landuse | industrial | PG | 169 | 1 | Predominantly workshops, factories, warehouses. | 0-3 4-7 | |
0x0006 | PG | 169 | 0 | Garages, vehicle sheds. | 0-3 4-7 | |||
landuse | brownfield | PG | 170 | 1 | A district to be developed, an empty area. | |||
landuse | greenfield | PG | 170 | 1 | Describes land scheduled for new development where there have been no buildings before. | |||
landuse | railway | PG | 171 | 1 | Area for railway use, generally off-limits to the general public. | |||
landuse | construction | PG | 172 | 1 | Something under construction. | |||
0x0004 | landuse | military | PG | 173 | 1 | For land areas owned/used by the military for whatever purpose. | ||
landuse | airport | PG | 401 | 1 | Airport area. | |||
0x0014 0x000d 0x0015 0x0016 0x0017 0x001e 0x001f 0x0020 0x0098 | natural | wood | PG | 184 | 2 | Natural woodland (trees). Only for completely unmanaged/wild areas. | ||
0x0051 0x0096 0x008b | natural | marsh | PG | 185 | 1 | Low poorly drained land that is sometimes flooded and often lies at the edge of lakes, streams, etc. | ||
0x0018 | sport | golf | PG | 194 | 1 | Golf course, football, stadium. | ||
building | palace | PG | 207 | 1 | A palace. | 0-2 3 | ||
building | postoffice | PG | 208 | 1 | A post office. | 0-2 3 | ||
building | restaurant | PG | 209 | 1 | A restaurant. | 0-2 3 | ||
0x006f 0x006f | amenity | public_building | PG | 210 | 1 | Public building. | 0-2 3 | |
0x0013 0x006c | building | yes | PG | 210 | 1 | General tag for buildings. | 0-2 3 | |
denomination | baptist catholic christian evangelical lutheran roman_catholic | PG | 211 | 0 | A church. | 0-2 3 | ||
0x9999 | surface | PG | 212 | 2 | Bottom surface. |
Gurtam Maps scale
Scale (km) | Scale (m) | Data level | Zoom level | Value |
0,02 | 20 | 0 | -1 | 2000 |
0,05 | 50 | 0 | 0 | 5000 |
0,1 | 100 | 0 | 1 | 10000 |
0,15 | 150 | 0 | 2 | 15000 |
0,2 | 200 | 0 | 3 | 25000 |
0,5 | 500 | 1 | 4 | 50000 |
1 | 1000 | 1 | 5 | 1000000 |
2 | 2000 | 1 | 6 | 2000000 |
5 | 5000 | 1 | 7 | 5000000 |
10 | 10000 | 1 | 8 | 10000000 |
20 | 20000 | 1 | 9 | 20000000 |
50 | 50000 | 2 | 10 | 50000000 |
100 | 100000 | 2 | 11 | 100000000 |
150 | 150000 | 2 | 12 | 150000000 |
200 | 200000 | 2 | 13 | 250000000 |
500 | 500000 | 2 | 14 | 500000000 |
