Work and rest routine for drivers
Wialon allows you to monitor whether drivers comply with AETR rules on work and rest hours.
The information about driver activity displayed in Wialon has no legal standing.
In this article, you can learn about the ways of monitoring the drivers’ work and rest routine and the AETR requirements that are considered in the system.
Monitoring drivers’ work and rest routine
To monitor the drivers’ work and rest routine, you can use the following methods:
For further information about monitoring the drivers’ work and rest routine, data sources and tachographs, see Tachographs and Wialon.
Work and rest requirements
Below, you can see all the work and rest requirements that are considered in the system and the seriousness of infringements.
For all the requirements that are monitored during one or two weeks, it is a working week that is taken into account. A working week is the period of time from the beginning of the first working shift after the previous weekly rest to the end of the next weekly rest. The exception to this is requirement 5, which refers to a calendar week (from 00:00 hours Monday to 24:00 hours Sunday).
Requirement
Norm
Infringement
Note
Minor
Serious
Very serious
Uninterrupted driving time
4,5 hours
Up to 5 hours
Up to 6 hours
More than 6 hours
Rest for every 4,5 hours of driving
45 minutes
An infringement of requirement 1 is registered, because if the driver rests for less than 45 minutes, this time is not regarded as rest but is included in the uninterrupted driving time. The exception is when the rest is broken down into parts (see requirement 3).
How to divide rest for every 4,5 hours of driving
The first part of rest must be no shorter than 15 minutes, the second part must be no shorter than 30 minutes.
An infringement of requirement 1 is registered because if the driver rests for less than the specified time, this is not considered as rest but is included in the uninterrupted driving time.
Daily driving time
9 hours
Up to 10 hours
Up to 11 hours
More than 11 hours
How to prolong daily driving time during a calendar week
Up to 10 hours, no more than 2 times
Up to 11 hours
Up to 12 hours
More than 12 hours
If the daily driving time is prolonged more than twice in a calendar week, an infringement of requirement 4 is registered.
Weekly driving time
56 hours
Up to 60 hours
Up to 70 hours
More than 70 hours
Total weekly driving time
90 hours
Up to 100 hours
Up to 112,5 hours
More than 112,5 hours
Daily rest time
11 hours
Up to 11 hours
Up to 10 hours
Up to 8,5 hours
How to reduce daily rest time
Up to 9 hours, no more than 3 time a week
The start of rest is delayed by 1 hour or less
The start of rest is delayed by 2 hours or less
The start of rest is delayed by more than 2 hours
If the daily rest time is reduced more than three times a week, an infringement of requirement 8 is registered.
How to divide daily rest time
The first part of rest must be no shorter than 3 hours, the second part must be no shorter than 9 hours. At least 12 hours in total.
The second part is less than 9 hours
The second part is less than 8 hours
The second part is less than 7 hours
Weekly rest time
45 hours
The start of rest is delayed by 3 hours or less
The start of rest is delayed by 9 hours or less
The start of rest is delayed by more than 9 hours
How to reduce weekly rest time
Up to 24 hours every other week (see note)
The start of rest is delayed by 4 hours or less
The start of rest is delayed by more than 4 hours
If the rest time in the first week was 24 hours, it should be at least 45 hours in the second week. In the third week, the rest time can again be reduced to 24 hours, etc.
Rest of each driver if there is more than one driver in the crew
At least 9 hours of rest within 30 working hours
