Import from WLP
This option allows you to import unit properties, resource contents, or user settings from a WLP file to an object of the corresponding type: a unit, a resource, or a user. To use this option, a previously saved WLP file is required.
Three import types are available.
Import typeDescription
ReplaceThe data is completely replaced, and the list of the data which should be imported contains all the possible fields, including the empty ones, so that the corresponding completed fields of the object can be cleared if needed.
MergeThe new data is added to the old data, and the items with the same name are replaced.
AppendThe new data is added to the old data, and the items with the same name are left as they are.
Regardless of the selected import type, the eco driving criteria are always imported using the Replace type, that is, the old criteria are deleted and the new ones are entered.
To import data, follow the steps below.
  1. In the user menu, select Import/Export and then Import from WLP.
  2. Click Browse and select the required WLP file.
  3. Click Upload. The selected file will be processed and its contents will be displayed in the Import options section.
  4. In this section, select the data which should be imported.
  5. Select the import type: ReplaceMerge, or Append.
  6. In the Destination items section, select the objects to which the data should be imported. To find the required objects quickly, use the dynamic search and various search criteria.
  7. Click OK. If all or some of the data has not been imported, a warning message is displayed on the screen. It contains a link to a file which you can download to see what data has been imported and what has not. You can see the import results in the log.
Import of vehicle types and subtypes
You can import the vehicle type and subtype to the unit properties. To do this, you should specify the key of the vehicle subtype in the import file. After importing the vehicle subtype, the corresponding type is automatically indicated in the Vehicle type field.
You can see the keys of vehicle subtypes in the tables below.
The keys of cargo transport subtypes:
Vehicle subtype
Key
Pickup
pickup
Van
van
Truck
truck
Heavy truck
heavy_truck
Dump truck
dump_truck
Logging truck
logging_truck
Tractor unit
tractor_unit
Trailers and semi-trailers
trailers_semi
Tanker trailer
tanker_trailer
Tank truck
tank_trailer
Refrigerator van
refrigerator_van
Other
other_cargo
The keys of passenger transport subtypes:
Vehicle subtype
Key
Kick scooter
kick_scooter
Bicycle
bicycle
Motorcycle
motorcycle
Passenger car
passenger_car
Minibus
minibus
Bus
bus
Trolleybus
trolleybus
Tram
tram
Other
other_passenger
The keys of special machinery subtypes:
Vehicle subtype
Key
Agricultural machinery
Tractor
tractor
Combine
combine
Sprayer
sprayer
Baler
baler
Agricultural spreader
agricultural_spreader
Mower
mower
Construction equipment
Bulldozer
bulldozer
Excavator
excavator
Backhoe loader
backhoe_loader
Loader
loader
Skid-steer loader
skid_steer_loader
Forklift
forklift
Hooklift
hooklift
Crane
crane
Manipulator
manipulator
Bucket truck
bucket_truck
Concrete mixer
concrete_mixer
Concrete pump
concrete_pump
Piling and drilling rig
piling_drilling_rig
Crusher
crusher
Trencher
trencher
Pipelayer
pipelayer
Road roller
road_roller
Road grader
road_grader
Paver
paver
Scraper
scraper
Special vehicles
Ambulance
ambulance
Garbage truck
garbage_truck
Fire truck
fire_truck
Street cleaning machine
street_cleaning_machine
Tow truck
tow_truck
Other
other_special
The keys of other vehicle subtypes:
Vehicle subtype
Key
Air transport
air_transport
Off-road vehicle
off_road_vehicle
All-terrain vehicle
all_terrain_vehicle
Snowmobile
snowmobile
Snowcat
snowcat
Rail transport
rail_transport
Water transport
water_transport
Recreational vehicle
recreational_vehicle
Other
other_vehicle
