Sent Commands
The commands sent to the unit by users are displayed on the Sent commands request. There is a special button in the monitoring panel to send commands to units.
The table includes the following columns.
Time — the time when the command was sent to the unit.
User — the login name of the user who performed the command. If there is a dash in this cell, it means you have no access to this user, that is why the login name is hidden.
Command name — the command name as it is written in the unit properties.
Command type — the command type (see the list).
Parameters — for the commands that require additional parameters (message to the driver, input activation/deactivation, report period, custom message, etc.).
Execution time — the time when the command was executed. If the execution failed due to billing limitations (e.g., you ran out of SMS messages), this column contains only dashes.
Channel — the type of connection used to transmit the command (TCP, UDP, Virtual, SMS).
