Unit Groups
Groups allow you to combine monitoring units by certain criteria. You can work with them in the monitoring system (the Groups mode on the Units tab) and in the management system (the Unit groups section).
The table of the Unit groups section contains all the created groups. In the section, you can also perform the following actions with them: create, copy, edit properties, and delete. To quickly find groups, use the dynamic filter.
Selecting columns
To select columns with additional information about unit groups, click on the icon  in the table header. In the menu, the following columns are available:
ColumnDescription
#The sequence number of the group in the table.
SelectThe selection of the group in the table.
IconThe group icon selected on the same-name tab of the group properties.
NameThe name of the groups specified in its properties.
CreatorThe user on whose behalf the group has been created.
AccountThe account to which the group belongs.
UnitsThe number of units added to the group.
Log
The icon  which allows you to open the log of the group.
Actions with unit groups
You can perform standard actions with unit groups:
In addition, you can use groups in the monitoring system. For more information, see the Using groups section.
