Hardware changelog
This changelog highlights new retranslator and device integrations, updates, and bug fixes.
May 5 – May 9, 2025
Integrations
Manufacturer | Device | Updates |
Jointech | Jointech JT705C | Integrated the new device Jointech JT705C. |
Tzone Digital Technology | TT18-4G | Integrated the new device TT18-4G. |
Changes and improvements
Manufacturer | Device/Retranslator | Updates |
TOPFLYTECH Co., Limited | Topflytech TLD2-D | Added the OBD parameters decoding for the 4103 content type. |
Ruptela | Ruptela Asset5 | Improved the LBS positioning parameters decoding. |
Wireless Links | Piccolo ST | Added the tag_nearest_id and tag_nearest_rssi parameters. |
AOVX | AOVX V-Series | Added support for BlueCircuites TDI CANBUS decoder via transparent channel. To get data from TDI, enable the Use TDI Telemetria by transparent option in the device configuration in the unit properties (![]() |
T-Zone | TT19 | Added the custom_msg command. |
Gurtam | Teltonika MB Server | Added new BLE message format decoding. |
WanWayTech | WanWay GS10G | Added Digital Inputs (0x1F) decoding into the din1 and din2 parameters. |
Jimi IoT (Concox) | VL106 | Improved commands for engine blocking and unblocking. |
April 28 – May 2, 2025
Integrations
BS Technotronics | BSTPL 17IS GLT | Integrated the new device BSTPL 17IS GLT. |
Tor.ai | Pluto 312 | Integrated the new device Pluto 312. |
Queclink Wireless Solutions | Queclink GV350M | Improved the decoding algorithm for the GTERI. |
WanWay Tech | WanWay GS12 | Added the acc_status parameter registration. |
April 21 – April 25, 2025
Integrations
BSJ Technology | BSJ Smart Watch S Series | Integrated the BSJ Smart Watch S Series. |
ORBCOMM | ORBCOMM Transportation Platform | Integrated the ORBCOMM Transportation Platform. |
AutoDefend | TTC-CV-P112, TTC-CV-P360, TTC-CV-P450 | Integrated the AutoDefend video devices. |
DAHUA TECHNOLOGY | Dahua DAE-CDR8213-GFW, MXVR4104-GFWI | Integrated the Dahua devices. |
Assistant Telematics | AVT20 | Added parsing of BLE data with the following parameters:
Rinho Telematics | All devices | Added ACK for messages with zero timestamp. |
Control T | Control T | Improved the algorithm for the Control T retranslator. |
Queclink Wireless Solutions | Queclink GV355CEU | Added the bt_nearest_mac2 and bt_nearest_rssi2 parameters.Improved the adc1 , adc2 , adc3 parameters decoding. |
Queclink Wireless Solutions | Queclink GV350M | Added GTTPM message parser with parameters:
iTER | Iter 155 | Added support for RFID reader via transparent channel. To get data from RFID reader, enable the RFID reader by RS232 option in the device configuration in the unit properties (![]() |
Vanguard IoT | Vanguard VA20 | Added the 0x51, 54, 58, E1, E2, E3 information IDs decoding with parameters:
Huiye IoT Technology | HYN100, HYN600 | Improved the decoding algorithm for the devices. |
Howen Technologies | Hero-ME40-02 | Added the Storage abnormal alarm (alarm_ec=16 ) decoding into the num and st parameter. |
Naturelink | Naturelink NL01, Naturelink NL02 | Added the Eurosens FLS and Eurosens DDS sensor data decoding with parameters:
April 14 – April 18, 2025
Meitrack | Meitrack MD522S | Fixed negative altitude parsing. |
iStartek | iStartek VT200L | Added parsing of event 53 (RFID) into a rfid_card_id parameter. |
TOPFLYTECH Co., Limited | Topflytech TorchX 100 | Added support for Escort DU Sensor via transparent channel. To get data from Escort DU Sensor enable the Use Escort DU Sensor option in the device configuration in the unit properties (![]() |
TOPFLYTECH Co., Limited | SolarX 120 | Added parsing of Alarm Message with LBS (From Server) (0x270x270x64). |
TOPFLYTECH Co., Limited | HeroX 100 | Added VIN parameter validation. |
Jimi IoT (Concox) | JC400 | Improved the curr_volt parameter registration. |
T-Zone | TT19 | Added the TT19SI and TT19SE sensor data decoding. |
Toptraking | Toptraking G50L | Added parsing of 0x1B packet. |
MiCODUS | MV710G | Added engine block/unblock command. |
Vanguard IoT | Vanguard VA12 | Changed name from Vanguard Asset Tracker to Vanguard VA12. |
WanWayTech | WanWay GS10G | Added the RFID decoding from the 0x94 message type into avl_driver parameter. |
Gosuncn | All products | Added support for the v4.0.0 protocol version with the following parameters:
April 7 – April 11, 2025
Queclink Wireless Solutions | Queclink GV350CEU | Added the GTDTT message type decoding into the dtt_data parameter. |
Toplovo | TL-900 | Added the Time zone correction property. For the correct message time registration fill in the device timezone in a Timezone field in the device configuration in the unit properties (![]() |
BS Technotronics | BSTPL 17IS BYD | Changed the parameters format from int to hex for the following parameters:
T-Zone | TT19 | Added decoding into the following parameters:
March 31 – April 4, 2025
Integrations
Transight | Discovery Series | Integrated the Discovery Series device. |
Queclink Wireless Solutions | Queclink GV50CEU | Added support for the HEX message type. |
Streamax Technology | All devices | Improved the data registration functionality. |
Streamax Technology | Streamax AD PLUS 2.0 | Improved the video receiving functionality by adding the playback stop function. |
Jointech | Jointech JT701D | Fixed timestamp decoding. |
Control T | Control T | Changed the property name for the Control T retranslator. |
Teltonika | Teltonika FMM13A, Teltonika FMM230, Teltonika FMM00A | Added an option to disable registration of command responses via transparent channel. To use this feature, enable the Do not register response to command option in the device configuration in the unit properties (![]() |
Cradlepoint | Cradlepoint IBR900 | Fixed a parsing error. |
Howen Technologies | All devices | Removed the Timezone property from unit properties. Timezone is now set automatically from the device configuration, including daylight saving time. |
flespi | Ruptela HCV5 Lite (flespi) | Improved parameter registration:
Vanguard IoT | Vanguard Standard Tracker | Added the 0xE1 information ID in 0x0900 packet with the following parameters:
See parameter description. |
Teltonika | Teltonika FMC125, Teltonika FMB130 | Added support for LinkedCore CAN60 via transparent channel. To receive data from LinkedCore CAN60, enable the Use LinkedCore CAN60 option in the device configuration in the unit properties (![]() |
March 24 - March 28, 2025
Integrations
BS Technotronics | BSTPL 17IS | Integrated the BSTPL 17IS device. |
Queclink Wireless Solutions | Queclink GV56 | Added the GTHBM and GTTOW packets decoding. |
Suntech | Suntech ST4215 | Improved command sending. |
Tramigo | Tramigo T24/T25 | Added the virtual channel for the commands. |
Teltonika | Teltonika FMA110 | Added coordinates for stationary units. |
Streamax Technology | All devices | Added parsing of GETSTORAGEINFO response. |
Assistant Telematics | AVT110 | Added the NMEA2000 mask field for AVT110. |
Ruptela | Ruptela Eco5 | Added the cmd_output_4th_gen command. |
March 17 - March 21, 2025
MettaX Digital (Shenzhen) Co., Ltd | MettaX MC904 | Added support for driver alignment packet (0E10) with the following parameters: - comparsion_res - aligh_similar_threshold - aligh_similar - alagh_type - driver_id - picture_format See parameter description. |
Queclink Wireless Solutions | Queclink GV57CG | Added Hour Meter Count registration into the hour_meter_count Wialon parameter. |
Queclink Wireless Solutions | Queclink GV55W | Improved mileage decoding. |
Queclink Wireless Solutions | Queclink GV350CEU | Added support for ET-45 Expander via transparent channel. To receive data from ET-45 Expander, enable the ET-45 Expander by transp option in the device configuration in the unit properties (icon ![]() |
Jimi IoT (Concox) | Concox JM-LL01 | Added SMS response decoding. |
Jimi IoT (Concox) | JM-LL303 | Added temperature and humidity data with timestamp decoding (0x58 Information content in 0x94 packet type) with the following parameters: - temp - hum See parameter description. |
SEEWORLD Technology Corporation | Seeworld R12L | Improved voltage parameter decoding. |
Assistant Telematics | AVT20 | Added Satellites Number Mask decoding with the following parameters: - gps_sats_num - beidou_sats_num - galileo_sats_num - glonass_sats_num |
T-Zone | TT19 | Added virtual channel for commands. |
Streamax Technology | All Streamax models | Added response to text parameter. |
Vanguard IoT | Vanguard Standard Tracker | Improved battery value decoding. |
March 10 - March 14, 2025
Integrations
TYT Electronics Co., Ltd. | IP668 | Integrated the IP668 personal tracking device. |
Suntech | Suntech ST8300 | Enhanced the custom_msg command format with the following improvements:- Added # as a separator- Implemented automatic unique ID filling - Added responses for REQ Example command: PRG;10;00#1;01#testapn.test |
Queclink Wireless Solutions | Queclink GV300W | Added support for CAN60 via transparent channel. To receive data from CAN60, enable the Use CAN60 option in the device configuration in the unit properties (icon ![]() |
Teltonika | Teltonika FMC650 | Added support for AL100 via transparent channel. To receive data from AL100, enable the AL100 by transp option in the device configuration in the unit properties (icon ![]() |
March 3 - March 7, 2025
Changes and Improvements
Meitrack | Meitrack MDVR MD500S | Added adaptation for the A9C Timeline and the option to choose AB8 Timeline. To use the AB8 timeline decoding type, enable the Uses AB8 command to generate timeline instead of A9C option in the device configuration in the unit properties (icon ![]() |
TOPFLYTECH Co., Limited | PioneerX 101 | Added acknowledgment support for the Accident via Acceleration Message (0x7) message type. |
TOPFLYTECH Co., Limited | Topflytech SolarGuardX 100 | Added commands to Add/Delete NFC IDs in the unlock white list. |
Suntech | Suntech ST8300 | Improved command sending functionality . |
Lytx | Surfsight AI-12 APIv2.0 | Fixed video retrieval functionality for devices connected to EU servers. |
Queclink Wireless Solutions | Queclink GV350CEU | Added option to register command responses in the driver chat. To receive command responses, enable the Registration of command responses option in the device configuration in the unit properties (icon ![]() |
Streamax Technology | Streamax AD PLUS 2.0 | Added HD option for Streamax devices. |
Baita Tecnologia | Baita MAC 4G | Improved Stop Duration (type 21) packet decoding. |
T-Zone | TT19 | Added TCP custom_msg command. |
Sukarne | Sukarne retranslator | Added refrigerator_van as type 2 for improved vehicle classification. |
Queclink Wireless Solutions | Queclink GB130MG | Added Queclink Track Protocol decoding. |
February 24 - February 27, 2025
Integrations
Manufacturer | Device/Protocol | Updates |
ROOTCLOUD | MachineLink API | Integrated the MachineLink API for industrial equipment monitoring. |
Apache | Apache thermograph | Integrated the Apache thermograph for temperature monitoring solutions. |
Queclink Wireless Solutions | Queclink Track Protocol | Added OBD data decoding with the following parameters:total_veh_dist , total_fuel_used , total_fuel_used_high_res , total_hours_oper , vehicle_speed , engine_rpm , engine_torque , engine_fuel_rate , fuel_lvl , fuel_lvl_2_tank , engine_cool_temp , acc_pedal_pos , engine_load , clutch_switch , brake_switch , cruise_control , pto_gov_state , park_brake_switch , brake_pedal_pos , act_retard_perc_torque , dr_demand_retard_perc_torque , retard_select_non_eng , retard_torque_mode_st , at_least_one_pto_eng , steering_wheel_angle , ambient_air_temp , door_status , transmission_gear , air_inlet_pressure , axle_weight_1 , axle_weight_2 , axle_weight_3 , axle_weight_4 , service_dist , service_brake_air_press_cir_1 , service_brake_air_press_cir_2 , ad_blue_tank_lvl , fuel_type , tot_gas_fuel_used , alternator_st_1 , alternator_st_2 , alternator_st_3 , alternator_st_4 , abs_ebs_amb_warn_signal_st , telltale_st , high_engine_temp , vin , driver_1_card_st , driver_2_card_st , driver_1_time_rel_st , driver_2_time_rel_st , driver_1_work_st , driver_2_work_st , driver_seat_belt , oil_lvl , coolant_lvl , tract_mount_trailer_abs_warn , hv_av_charge_power , hv_av_discharge_power , hv_tot_energy_throughput , hv_battery_volt , hv_cell_volt_max , hv_cell_volt_max_num_st , hv_cell_volt_min , hv_cell_volt_min_num_st , range_dist , hv_total_charge_energy , soc , soh , hv_cell_minmax_mux_st , hv_cell_temp_max , hv_cell_temp_max_num_st , hv_cell_temp_min , hv_cell_temp_min_num_st , hv_battery_curr , hv_battery_temp , hv_charge_st , tire_press , oil_temp , v12_batt_volt , tire_loc .See parameter description. |
Jimi IoT (Concox) | VL103, JM-VL03M | Improved the block_engine and unblock_engine commands. |
MiCODUS | MiCODUS MV930G, MiCODUS MV710G | Added 0x8500 packet decoding for expanded device functionality. |
Queclink Wireless Solutions | Queclink Track Protocol | Fixed negative altitude value calculation. |
Shenzhen Coban Electronics | Coban GPS303-C | Improved block_engine and unblock_engine commands. |
Ruptela | Ruptela Eco5 Lite | Added new parameters: - beacon_nearest_id - beacon_nearest_rssi - io_8_760_hex - io_8_761_hex |
February 17 - February 21, 2025
GLONASSsoft | UMKa302 | Added Wialon ecodriving parameters for driver behavior monitoring: - wln_accel_max - wln_brk_max - wln_crn_max |
Ruptela | All Ruptela devices | Added setcfg command. |
Shenzhen Cantrack Technology Co., Ltd | Cantrack G05 | Fixed speed calculation algorithm. |
Teltonika | Teltonika FMB125 | Added support for Digi-Star GT400 via transparent channel. To receive data from Digi-Star GT400, enable the Parse data from Digi-Star GT400 option in the device configuration in the unit properties (icon ![]() |
Assistant Telematics | AVT110, AVT20, AVT50 | Fixed total_mileage and mileage parameters registration. |
Lytx | Surfsight AI-12 APIv2.0 | Added query_photo command to request on-demand images from the device. |
GoTrack | G400 | Fixed location calculation. |
February 10 - February 14, 2025
Integrations
Xexun | DDX04 | Integrated the new DDX04 personal tracking device. |
eTrans Solutions | DARSH_Lite | Added the following parameters:packet_type , source_id , task_status , command_source , cmd_type , ot_string , sequence , firm_ver , packet_status , veh_num , net_oper , net_type , signal_pwr , main_pwr , pwr_int , ext_adc , dev_state , mileage , dyn_field_# , rfid , rfid_msg , key_val , key_msg , fuel_sensor_N , fuel_temp_$num , fuel_temp_Nmsg , uhf_card , cell_id , lac , mnc , mcc , tmpN , prev_speed , cur_speed , alert_calc See parameter description. |
Jointech | Jointech JT709A | Added SMS command sending channel. |
Assistant Telematics | AVT110 | Improved decoding of all_geo_status and driver_id parameters. |
Assistant Telematics | AVT20 | Improved decoding of the main_pwr_vcc parameter. |
Teltonika | All Teltonika devices | Renamed block/unblock engine commands to “CAN-CONTROL Block/Unblock engine”. |
Jimi IoT (Concox) | JM-LL303 | Improved BLE beacon parameters decoding. |
iStartek | iStartek VT300-L, iStartek PT60-L, iStartek VT100L, iStartek VT200L | Added new commands. |
Tramigo | Tramigo T24 | Improved command response decoding. |
SEEWORLD Technology Corporation | Seeworld S5L | Added support for weight sensor data decoding. To receive weight data, enable the Register weight data option in the device configuration in the unit properties (icon ![]() Added 0x30 packet decoding with the following parameters: - rfid_hex - rfid |
3 February - 7 February, 2025
Integrations
BWS IoT | E3+4G | Integrated the E3+4G device. |
Teltonika | Teltonika FMC225 | Added support for JT606X fuel level sensor via transparent channel. To get data from JT606X, enable the JT606X sensor by transp option in the device configuration in the unit properties (icon ![]() The following parameters appear in messages: - jt606x_fuel_id - jt606x_command_code - jt606x_remaining_fuel_perc - jt606x_fuel_level - jt606x_fuel_level_litres - jt606x_fixed See parameter description. |
Lytx | Surfsight AI-12 APIv2.0 | Added the possibility of choosing the EU region of service. To get data from EU server, enable the Use EU region of service option in the device configuration in the unit properties (icon ![]() |
Suntech | Suntech ST4305 | Added the l_asgn{i}_dec parameter that represents the decimal value of the l_asgn , where {i} index shows the number of the l_asgn parameter. |
Gosuncn | Gosuncn GD201 | Fixed the temp_{i} parameter registration. |
Baita Tecnologia | Baita MAC 4G | Added decoding for the following packet types: 17 , 18 , 23 , 25 , 26 , 27 , 28 , 29 , 48 . |
Streamax Technology | All Streamax devices | Added the possibility to choose the livestream and playback quality. |
27 January - 31 January, 2025
Integrations
Jimi IoT (Concox) | JC371 | Integrated the JC371 Jimi IoT (Concox) device. |
Altotrack | Altotrack | Integrated the Altotrack retranslator. |
Atlanta Systems Pvt Ltd. | L400 | Added data decoding from multiple LLS sensors. |
WanWayTech | WanWay GS10G | Added Escort BLE FLS data parsing with the following parameters: - fuel_freq - fuel_temp - fuel_batt See parameter description. |
Teltonika | Teltonika FMC225 | Added support for secondary Unique ID. |
Howen Technologies | All devices | Removed _video commands from vrt commands. |
Assistant Telematics | AVT110, AVT130 | Improved the multi-package messages decoding functions. |
Howen Technologies | Hero-MC30-01 | Renamed the following parameters: - dur → trip_dur - max_speed → trip_max_speed - avg_speed → trip_avg_speed See parameter description. |
Iridium | Iridium Edge Solar | Fixed the negative longitude values registration. |
Meitrack | Meitrack T622G | Added command for Iridium satellite periodic data upload interval. |
20 January - 24 January, 2025
Integrations
Gurtam | flespi gateway | Integrated video receiving from the flespi platform (stream and playback). |
TOPFLYTECH Co., Limited | CyberLabelX 100 | Integrated the CyberLabelX 100 device. |
Sensata INSIGHTS (Xirgo Global) | Xirgo FMS500 TACHO | Fixed speed registration for the Use CAN speed (truck and bus) option in the device configuration in the unit properties (icon ![]() |
Sensata INSIGHTS (Xirgo Global) | Xirgo XT-4600 | Improved the decoding algorithm for Wialon Local. |
Howen Technologies | Hero-ME41-04 | Added registration for the following parameters: - modem_status - trigg_threshold - alc_concentr See parameter description. |
Ministry of Transport of the People’s Republic of China | JT808 | Improved the ACK (0x8103 ) command formation. |
Digital Matter Telematics | Barra Edge | Added cell tag decoding with the following parameters: - mcc - mnc - lac - cid - rsrq - rx_lvl - taN - srvN - nwN - earfcnN - pcidN - rsrqN - delta_tN See parameter description. |
Queclink Wireless Solutions | Queclink GV355CEU | Added decoding for the GTALM packet type into alm_N parameters. To use this functionality, enable the Parse GTALM parameters option in the device configuration in the unit properties (icon ![]() |
Navtelecom | Navtelecom SMART S-24xx | Improved the decoding algorithm. |
13 January - 17 January, 2025
Integrations
Widetech | WEB LOCATION REPORTER | Integrated the Web Location Reporter retranslator. |
API Tkontrol | API Tkontrol | Integrated the Tkontrol retranslator. |
Teltonika | Teltonika FMC125 | Improved the io_109 parameter registration. |
Queclink Wireless Solutions | Queclink GV355CEU | Added registration for the RESP:GTCAN packet with the following parameters:report_head , report , buffer , msg_type_name , can , dev_type , proto_ver , can_ign_key , can_total_distance , tco_distance , can_total_fuel , can_eng_rpm , can_speed , can_eng_cool_temp , can_range , can_acc_pedal_press , can_total_eng_hours , can_total_driv_time , can_total_eng_idle , can_total_idle_fuel , can_tacho_inf , tco_activity_type1 , tco_activity_type2 , can_detail_inf , can_lights , can_doors , can_total_veh_ovspd , can_total_eng_ovspd , can_eng_cold_starts , can_eng_all_starts , can_tacho_ovspd , can_tacho_motion_sign , can_tacho_driv_direction , can_ain1 , can_eng_braking_factor , can_pedal_braking_factor , can_total_accel_kickdowns , can_total_effective_eng_speed_time , can_total_cruise_cntrl_time , can_total_accel_kickdown_time , can_total_brakes , can_reg_number , can_exp_info , tacho_info_expand .See parameter description. |
Queclink Wireless Solutions | Queclink GV75M | Changed the parameter name from bat_status to ext_pow_supply . |
Queclink Wireless Solutions | Queclink GV75 LTE | Added the ext_pow_supply parameter. |
Suntech | Suntech ST8310U | Improved the command-sending functionality. |
Toptraking | Toptraking G50L | Improved the set_report_interval TCP command. |
Shenzhen Cantrack Technology Co., Ltd | Cantrack G08L | Added decoding for the 0x0701 command type answer. |
Shenzhen Cantrack Technology Co., Ltd | Cantrack G06L | Added the ACK for heartbeat messages. |
TOPFLYTECH Co., Limited | PioneerX 101, HeroX 100 | - Improved decoding for the 0x252523 message type.- Added the 1wire_device_type parameter.See parameter description. |
BS Technotronics | BSTPL 17IS CAN | Improved the max_cell_volt parameter registration. |
Assistant Telematics | AVT110 | - Added ACK for the CVS , CMI , and VER packets.- Improved time registration for multi-package message decoding. |
Assistant Telematics | AVT20 | Improved the multi-package message decoding functions. |
Naturelink | Naturelink NL02 | Added the following parameters:ble_N_rssi , ble_N_hw_ver , ble_N_fw_ver , ble_N_status , limp_mode , alco_alarm , alco_value , alco_units , escort_N_rssi , escort_N_mode , escort_N_event , escort_N_angel , escort_N_temp , escort_N_pwr_int .See parameter description. |
CARVIS | All devices | Removed _video_N commands from vrt_commands . |
Streamax Technology | Streamax AD PLUS 2.0 | Improved the GETSUPPORTSERVICE request function. |
6 January - 10 January, 2025
Manufacturer | Device/Application | Updates |
Gurtam | TCA | Fixed the application for remote DDD-file downloading. Download the latest version here. |
Assistant Telematics | ATL100 | Renamed MTL100 to ATL100. |
30 December, 2024 - 3 January, 2025
Integrations
Totarget | GW005 | Added support for the GW005 device. |
Shenzhen Ultravision Technology Co., Ltd. | Ultravision B series | Added support for the Ultravision B series device. |
Gurtam | flespi gateway | Added functionality for saving tachograph files. |
23 December - 27 December, 2024
Assistant Telematics | AVT110 | Changed time registration to use the Generated Time parameter from the data packet. |
Jimi IoT (Concox) | LL704 | Added decoding for the 0xA1 packet type without specific parameters. |
Queclink Wireless Solutions | Queclink GV350CEU | Added decoding for the GTTPM packet type into the following parameters:- tire_position_N - tire_bat_volt_N - tire_press_N - tire_temp_N - tire_status_N - tire_time_out_N - tire_rf_quality_N - tire_ref_press_N See parameter description. |
Queclink Wireless Solutions | Queclink Track Protocol | Changed time registration to use the Generated Time parameter from the data packet. |
Streamax Technology | Streamax AD PLUS 2.0 | Improved the algorithm for downloading videos. |
16 December - 20 December, 2024
Integrations
STONKAM CO.,LTD | Stonkam MDVR | Integrated the Stonkam MDVR device. |
Queclink Wireless Solutions | Queclink Track Protocol | Added registration for the 0d7 , 0d17 , and 0d43 Data IDs in the following parameters:- io_state - rf433_state - current_working_mode See parameter description. |
Queclink Wireless Solutions | Queclink GV58CEU | Added decoding for the GTALM packet type into alm_N parameters. To use this functionality, enable the Parse GTALM parameters option in the device configuration in the unit properties (icon ![]() |
Queclink Wireless Solutions | Queclink GL50B LITE | Added the report_type_gtgeo parameter. |
Queclink Wireless Solutions | Queclink GV350CEU | Added support for saving multiple CAN parameters in hexadecimal format. |
Queclink Wireless Solutions | Queclink GV50CEU | Added decoding for the GTASC packet type for ASCII sending type. |
Hikvision | Hikvision AE-DI2032-G40, Hikvision AE-DI5042-G4 | Fixed negative coordinate values for the 0x0801 package type. |
Ruptela | Ruptela Pro5 Lite | Added support for the KNOV keyboard via transparent channel. To get data from the KNOV keyboard, enable the KNOV keyboard by transp option in the device configuration in the unit properties (icon ![]() |
Ruptela | Ruptela Trace5 | Added support for the UDP channel for the output_on and output_off commands. |
Jimi IoT (Concox) | JC450 | Added support for GS-601 via transparent channel. To get data from GS-601, enable the GS-601 by transparent option in the device configuration in the unit properties (icon ![]() |
Shenzhen Esino Technology | ES-GP06 | Fixed decoding for the status parameter. |
9 December - 13 December, 2024
Integrations
Hikvision | Hikvision AE-DI2032-G40 | Added support for the Hikvision AE-DI2032-G40 device type. |
Streamax Technology | Streamax AD PLUS 2.0 | Added registration for the CONFIGMODEL packet with the following parameters:- camt - cast - cp - cport - ctport - cuport - en - etls - gpsex - gpss - lgk - mport - mtport - muport - nbb - nwt - ruf - ms - cs See parameter description. |
TechnoKom | Avtograph | Added support for stationary coordinates. To use the Coordinates for stationary units functionality, enter the coordinates in the corresponding field in the device configuration in the unit properties (icon ![]() |
Shenzhen Coban Electronics | GPS103-B | Added registration for the battery parameter. |
Think Power | Think Power TL-904D | Added support for 0xA2 and 0x29 packet types with the following parameters:- sa_slot - sa_direction - sa_status - sa_circle - total_millage - total_work_tm See parameter description. |
ControlT | ControlT | Improved the ControlT retranslator. |
Sensata INSIGHTS (Xirgo Global - BCE) | BCE IOTM | Improved the algorithm for constructing tachograph file names for BCE devices. |
Assistant Telematics | MTL100 | Improved registration for the 1wire_temp_id parameter. |
Suntech | Suntech ST449 | Added support for receiving messages via LoRaWAN. |
Gosuncn | Gosuncn GT117, Gosuncn GD201 | Added support for FOTA functionality. Firmware can now be updated from Wialon using the Request MCU update command. |
Sukarne | Sukarne | Improved the Sukarne retranslator by converting event message type values to integers. |
2 December - 6 December, 2024
AOVX | AOVX V-Series | Added support for Getscale GS-601 via transparent channel. To get data from the RFID reader, enable the Use Getscale GS-601 option in the device configuration in the unit properties (icon ![]() |
Globalstar | Globalstar SmartOneC | Changed the default state of the Used firmware version 2.1 device configuration property to active. |
Queclink Wireless Solutions | Queclink GV620MG | Added support for registering BLE accessory MAC addresses in raw format. To save bt_mac_N in the corresponding format, enable the Raw MAC-address format option in the device configuration in the unit properties (icon ![]() |
Queclink Wireless Solutions | Queclink GV50CEU | Improved decoding for the GTHBE packet. |
LinkedCore | Linkedcore | Improved decoding for the driver_id parameter. |
Teltonika | Teltonika TRB245 | Added the option for receiving data via MQTT. |
GoTrack | G400 | Improved longitude registration. |
Jimi IoT (Concox) | JC261 | Added support for naming video files based on events detected by the device. |
NAL Research | Shout Nano | Added the emergency_clear command type to stop the emergency alarm. |
25 November - 29 November, 2024
Jimi IoT (Concox) | JC450 | - Added support for the Getscale GS-404 via transparent channel. To get data from the RFID reader, enable the Getscale GS-404 by transparent option in the device configuration in the unit properties (icon ![]() - Added decoding of the peripheral data packet 0x2007 into the peripheral_{peripheral_id}_val parameter. |
Queclink Wireless Solutions | Queclink GV350CEU | Added parsing for the GTBAR packet with the following parameters:- bt_index - bt_type - bt_model - bt_access_mask - bt_mac - bt_status - bt_vers - bt_pgn_N - bt_pgn_data_N - mcc - mnc - lac - cell_id - gnss_trigger_type See parameter description. |
Queclink Wireless Solutions | Queclink GV620MG | Added parsing for the GTBID and GTBIE packets with the following parameters:- bt_detected_count - bt_total_frame - bt_frame_index - bt_beacon_number - bt_model_id_N - bt_mac_N - bt_pwr_int_N - bt_rssi_N - bt_temp_N - bt_nearest_mac - bt_nearest_rssi See parameter description. |
Gurtam | flespi gateway | Changed the parameter names: - flespi total_trip_energy_consumed renamed to Wialon ttl_trip_enrg_con - flespi ev_economy_information renamed to Wialon ev_eco_info |
Teltonika | Teltonika FMB130 | Added decoding for the io_282 parameter into dtc_fault . |
Sensata INSIGHTS (Xirgo Global - BCE) | BCE FM Blue | Improved the decoding algorithm to prevent rollover value errors after January 4, 2025. |
18 November - 22 November, 2024
Integrations
ERM Advanced Telematics | IoTLink Shadow | Integrated the IoTLink Shadow device. |
Here’s the continuation of the table with these additional entries:
Howen Technologies | Hero-ME41-04 | Added decoding for the following parameters: - driver_data - bluetooth_data See parameter description. |
Multi Portal | RST-TG100 | Added support for TCP connection. |
Queclink Wireless Solutions | Queclink GV55W | Added decoding for the mileage parameter in the following packet types:- GTEPS - GTRTL - GTDOG - GTIGL |
Ruptela | Ruptela Pro5 Lite | Improved parsing for TPMS (Tire Pressure Monitoring System) data. |
Gosuncn | Gosuncn GT300 | Improved the set_device_parameters command to allow setting multiple parameters at once. |
Linkedcore | all devices | Added registration of the Driver ID field (0xf9 ) to the driver_id parameter. |
11 November - 15 November, 2024
Integrations
Manufacturer | Device/Protocol/Retranslator | Updates |
Intelbras | Moovsec API | Added support for the Moovsec protocol. |
AI27 predictive inteligence | AI27 | Added support for the AI27 retranslator. |
Autoseeker Electronics | AT-17 | Integrated the AT-17 device. |
Howen Technologies | Hero-ME41-04 | - Improved coordinates decoding from the 0x1092 message type. - Added decoding for the iccid parameter. |
Howen Technologies | Hero-ME41-02 | Improved audio and video synchronization for Howen devices. |
Gurtam | Wialon IPS | Improved video receiving functionality for the Wialon IPS protocol. |
Galileosky | all devices | Improved the decoding algorithm for all devices. |
Milesight | Milesight IoT | Added the ability to send commands to the gateway server. |
Naturelink | Naturelink NL02 | Added decoding for the following parameters:lls_net_number , lls_temperature , lls_level , lls_frequency , escort_fuel_d2_number , escort_fuel_d2_fuel_level , escort_fuel_d2_battery_voltage , escort_fuel_d2_temperature , eye_sensor_realtime_mac , eye_sensor_rssi , eye_sensor_temperature , eye_sensor_humidity , eye_sensor_mov_sensor_state , eye_sensor_mov_sensor_angle , eye_sensor_battery_voltage , pulse_speed , mcu_temperature , eddystone_realtime_mac , eddystone_rssi , eddystone_calibrated_tx , eddystone_namespace , eddystone_instance , eddystone_rfu , eddystone_prefix , eddystone_url , eddystone_tlm_ver , eddystone_tlm_vbatt , eddystone_tlm_temp , eddystone_tlm_ad_pdu_c , eddystone_tlm_on_time , eddystone_ephemeral_id See parameter description. |
Globalstar | Globalstar SmartOneC | Added support for the SmartBridge fuel level sensor via transparent channel. To get data from the sensor, enable the User data as SmartBridge FLS option in the device configuration in the unit properties (icon ![]() |
Queclink Wireless Solutions | GV501LG | Improved decoding of messages with unfixed coordinates. |
Queclink Wireless Solutions | Queclink GV355CEU | Added decoding for the GTTPM data packet with the following parameters: - tire_bat_volt_N - tire_press_N - tire_temp_N - tire_status_N - tire_position_N See parameter description. |
4 November - 8 November, 2024
Integrations
Manufacturer | Retranslator | Updates |
MappointAsia | MappointAsia | Added the MappointAsia retranslator. |
NEWTEC | VIRLOC VL08 | Added registration for command answers. |
Think Power | Think Power TL-904D | Added the following parameters: - ibutton_bcr - scan_id See parameter description. |
Queclink Wireless Solutions | Queclink GV300CAN | Added decoding for the GTCRA packet type. No new parameters were added. |
Queclink Wireless Solutions | Queclink GV58CEU | Added registration for the card_id parameter for the GTERI packet type.See parameter description. |
Gosuncn | Gosuncn GD201 | Added support for 0x04 Major and 0x0D Minor data types with the following parameters: - accel_x - accel_y - accel_z - rpm - tm_interval - vehicle_speed - data_type - source - sensor_study_status - is_from_past - hacc - navigation_status See parameter descriptions. |
Jimi IoT (Concox) | JC450 | Added support for the command response in the Chat with driver window. |
Jimi IoT (Concox) | JC400D | Improved functionality for receiving video from the device. |
Howen Technologies | Hero-ME41-04 | Improved message time registration for the 0x1051 message type. |
28 October - 1 November, 2024
Hikvision | Hikvision AE-DI5042-G4 | Added options for fixing negative latitude and longitude. If the device sends incorrect latitude or longitude values, enable the Always use negative latitude value or Always use negative longitude value option in the device configuration in the unit properties (icon ![]() |
Galileosky | Galileosky 10 | Added Galileosky tags 0x253 (parameter ibutton64 ) and 0x254 (parameter ibutton64_2 ) to the Registration ibutton as hex option in the device configuration in the unit properties (icon ![]() |
Jimi IoT (Concox) | Concox JM-LL01 | Improved time value parsing for 0x33 and 0x34 data packets. |
Peak Tech Power Limited | L19 | Added the BP40 Send Text Message option for the Send command with custom parameter command. |
Toptraking | Toptraking G50L | Added registration of 0x82, 0x83, and 0x94 packets for the following parameters: - charge_completed - charge_connected - vibr_alarm See parameter descriptions. |
Shenzhen HHD Technology | GPS Padlock G-508 (New Protocol) | Improved the platform_cmd command description. |
Teltonika | Teltonika FMC650 | Improved video request from the DualCam. |
Queclink Wireless Solutions | Queclink CV100LG | Improved video request from the device. |
ERM Advanced Telematics | StarLink Tracker | Improved decoding of edome fuel level sensor messages. |
WanWayTech | WanWay GS10G | Improved decoding of BLE sensor MAC addresses. |
Think Power | Think Power TL904M | Improved the process for sending commands from the server. |
Verizon Connect | Inoslv V8 | Added new parameters:distance_total , distance_cruise , fuel_con_total , fuel_cons_pto , fuel_cons_idle , fuel_cons_driving , fuel_cons_cruise , time_cruise , time_pto , time_idle , time_driving , engine_hours , version_num , engine_status , max_engine_speed , max_veh_speed , inc_distance , inc_fuel_cons , average_fuel_lvl , max_acc_pedal , clutch_pedal , min_veh_speed , fuel_eco_range , time_eco_range , distance_eco_range , breaks_num , harsh_breaks_num , harsh_acc_num , time_high_rpm , time_high_temp , fuel_high_rpm , distance_high_rpm .See parameter descriptions. |
21 October - 25 October, 2024
Integrations
STONKAM CO.,LTD | ADA44 | Integrated the ADA44 device. |
MITRE | Cursor on Target | Integrated the Cursor on target protocol. |
Sitrack | Sitrack | Integrated the Sitrack retranslator. |
Vanguard IoT | Vanguard Asset Tracker | Integrated the Vanguard Asset Tracker. |
Onboard Eletronics | OnBoard Eletronics OnLink | Integrated the OnBoard Eletronics OnLink protocol. |
eTrans Solutions | DARSH_Lite | Integrated the DARSH_Lite device. |
Teswell | Teswell 830X | Added decoding of temperature and humidity sensors (0xE2 packet) with the following parameters: - humidityN - device_humidity - device_temp - tempN - air_qualityN See parameter description. |
Meitrack | Meitrack T622G | Added support for Iridium channel connection. |
Queclink Wireless Solutions | Queclink GV57CG | Improved decoding of the GTERI packet type. |
Gosuncn | Gosuncn GT300 | Added support for the set_device_parameters command. |
TOPFLYTECH Co., Limited | Topflytech TLW2-12BL, Topflytech T8803+ | Improved decoding of BLE sensor data. |
Sensata INSIGHTS (Xirgo Global - BCE), Caiquén | BCE IOTM, Caiquén 212 | Added support for the Caiquén 212 accessory via transparent channel. To get data from Caiquén 212, enable the Use Caiquén 212 option in the device configuration in the unit properties (icon ![]() |
ATrack | ATrack AK500 | Added BLE data decoding with the following parameters: - ble_mac_N - rssi_N - humidity_N - temp_data_N - type_N - mag_data_N See parameter description. |
Iridium | Iridium Edge Pro | Improved the decoding algorithm. |
Teltonika | Teltonika FMB140 | Added io_10828 parameter to the decoding algorithm. |
Teltonika | Teltonika FMC650 | Improved registration of DDD file names. |
Teltonika | Teltonika FMC125 | Added support for the Uface 5 by RS-232 Delimiter accessory. To get data from Uface 5, enable the Uface 5 by RS-232 Delimiter mode option in the device configuration in the unit properties (icon ![]() |
Think Power | Think Power TE604E | Added registration of the sos parameter for the 0x10 SOS record type. |
14 October - 18 October, 2024
Integrations
T-Zone | WF501B | Integrated the WF501B asset tracker. |
GoTrack | G400 | Integrated the G400 asset tracker. |
Queclink Wireless Solutions | Queclink Track Protocol | Added the following parameters: - tamper_curr_status - tamper_prev_status - tamper_prev_dur See parameter description. |
Howen Technologies | Hero-ME41-04 | Added support for the 0x4040 subscription upload model functionality. To choose the message upload model, enter the value into the 0x4040 subscription upload model field in the device configuration in the unit properties (icon ![]() |
BoShiJie Technology | EG01G | Improved parameter naming. See parameter description. |
LinkedCore | LinkedCore | Added support for parsing Escort DU parameters. The following parameters are now available: - ble_escort_dev_type_N - ble_escort_sens_mode_N - ble_escort_rpm_N - ble_escort_evnt_notif_on_N - ble_escort_evnt_notif_cnt_N - ble_escort_tilt_angle_N - ble_escort_tot_rev_cnt_N - ble_escort_temp_N - ble_escort_roll_N - ble_escort_pitch_N - ble_escort_pwr_int_N - ble_escort_fw_vers_N - ble_escort_content_type_N - ble_escort_name_N - ble_escort_rssi_N See parameter description. |
7 October - 11 October, 2024
Teltonika | FMB140 | Fixed the registration of the following parameters: - beacon_count - beacon_nearest_id - beacon_nearest_rssi |
Teltonika | FMB640 | Added decoding of responses for the query_pos command. |
Toptraking | Toptraking G50L | Added the iccid parameter. See parameter description. |
Assistant Telematics | AVT110 | Added parsing of +VER, +CVS, and +CMI packets with the the following parameters: protocol_ver , can_car_model_id , can_car_name , can_sync_status , firmware_ver , hardware_ver , modem_software_ver , can_version_num , can_serial .See parameter description. |
Streamax Technology | Streamax X3-H0402 | Improved the decoding algorithm for the door status change. |
Baita Tecnologia | Baita MAC 4G | Added the reset command. |
EGTS | EGTS | Added parsing for EGTS_SR_DISPATCHING packet into the following parameters: route_num , direction .See parameter description. |
BoShiJie Technology | EG01G | Improved decoding algorithm for parsing sub-packets 0x0121 and 0x0122. |
A-Telematics | AT08 | Added parsing for 0x1B packets with the following parameters: ad1 , ad2 .See parameter description. |
DCT | Syrus Pegasus Gateway | Added the flow_meter_display_state parameter. |
Lynkworld | Lynkworld LW2G-4A | Added the bat_pwr parameter registration. |
SGBras | SGBras keyboard | Added the sgbras_journey_num parameter. |
E3Innovations Oy | E3Blue | Improved the data request frequency for location packets to 30 seconds. |
Queclink Wireless Solutions | Queclink Track Protocol | Added registration for the following parameters: - intern_temp - intern_temp_tm - battery_basic_status - battery_voltage - battery_percent - battery_charging See parameter description. |
Queclink Wireless Solutions | Queclink GV310LAU | Added the ign parameter for GTIGN and GTIGF packet types. |
Great-Will | GAT23 | Added the tkstar_light_alarm parameter.See parameter description. |
Meitrack | Meitrack T399 Series | Added the rfid_hex parameter.See parameter description. |
30 September - 4 October, 2024
Integrations
Here’s the continuation of the table with this final entry:
Kirsen Global Security | Kirsen API | Integrated the Kirsen API asset tracker. |
Teltonika | Teltonika ADAS | Improved video file receiving functionality. |
PCL | PCL109 ADAS_DMS_BSD Dashcam | Improved video file receiving functionality. |
Queclink Wireless Solutions | Queclink GV350CEU | Added the bt_raw_data_dec parameter.See parameter description. |
Queclink Wireless Solutions | Queclink GV55S | Added the following parameters: - svr_state - ghost_mac - svr_append_info See parameter description. |
Jimi IoT (Concox) | JM-VL03M | Added the mileage parameter.See parameter description. |
Galileosky | All device types | Added parsing for device SMS responses. |
Jimi IoT (Concox) | PL200 | - Added parsing for device command responses. - Added the following parameters: - content - encoding - server_flag See parameter description. |
Garmin | inReach MINI | Added the update_tracking_status command. |
Megastek Technologies | Megastek MT60X | Added coordinate registration for messages with “V” GPS fix. |
23 September - 27 September, 2024
Integrations
Global Satellite Engineering | GSatSolar | Integrated the GSatSolar asset tracker. |
Digital Matter Telematics | Barra Edge | Added the following commands:resync_device_slots , reboot , set_operat_mode , set_digital_output , immobilise , reset_device_stats . |
Queclink Wireless Solutions | Queclink GV57MG | Added parsing of the +RESP:GTALM packet with the following parameters:alm , buffer , current_packet , dev_type , msg_type_name , proto_ver , report , report_head , total_packets .See parameter description. |
Teltonika | Teltonika FMB640 | Added SMS parsing for Teltonika FMB640 in Wialon Hosting and Local versions 2204 and 2304. |
iTR | iTR 270 | Added the following parameters: - rpm - login_tm - ibutton - total_mileage - freq - temp See parameter description. |
WanWayTech | WanWay GS10G | Added the following parameters: - bid_db - nid_db See parameter description. |
Iridium | Iridium Edge Solar | Added speed and course data registration for packets 0x03, 0x04, and 0x05. |
Queclink Wireless Solutions | Queclink GV310LAU | Added acc_x , acc_y , and acc_z parameters for the +RESP:GTHBE packet. |
16 September - 20 September, 2024
Integrations
Tramigo | Tramigo TF150 | Integrated the Tramigo TF150 device. |
BoShiJie Technology | EG01G | Added the packets 0x0702, 0x0900 and the additional info packets 0x0115 (can be copied from jt808), 0121, 0122, 0123, 0124, 0125, 0126, 0127 with the following parameters:tco_insert_card , tco_insert_time , tco_ic_card_read , tco_driver_name , tco_qual_cert_code , tco_notif_body_name , tco_cert_term , mileage , manufacturer_data_N , fuel_tank_lvl_N , oil_level_N , temp_N , state_N , manufacturer_data , fuel_tank_height , oil_volume_level , vbat , temperature , accel_(x/y/z) , fuel_meter_stability , fuel_level_stability , cover_sensor , channels , mac_N , device_pitch_N , device_roll_N , motion_status_N , motion_event_count_N , mark_N , fuel_meter_data_type , oil_perc , oil .See parameter description. |
Geometris | whereQube OBD | Added support for JSON file parsing. To get data, enable the Report formats configuration file (.json) option in the device configuration in the unit properties (icon ![]() |
Assistant Telematics | AVT110 | - Improved UART1 info data decoding. - Added the rto_command command. |
WanWayTech | WanWay GS10G | Improved the BLE sensors data parsing. |
Queclink Wireless Solutions | Queclink GB100MG | Added decoding for +RESP:GTBMC and +RESP:GTBML packets with the following parameters:m1000_mac , command , result , scanned_mac_N , arm_state , enrolled_users_num , enrolled_user , connected_key , starter_relay , m1000_mode , auto_arm_delay_time , connection_status , owner_mac .See parameter description. |
Gurtam | Wialon Combine | Improved functionality for sending UDP commands. |
Baita Tecnologia | Baita MAC 4G | Added support for speed decoding in km/h. To use this feature, enable the Convert speed from knots to km/h in the device configuration in the unit properties (icon ![]() |
Gosuncn | Gosuncn GD201 | Added parsing for 0x040D packet with the following parameters:accel_x , accel_y , accel_z , rpm , tm_interval , vehicle_speed , data_type , sensor_study_status , navigation_status , hacc .See parameter description. |
Toptraking | Toptraking G50L | - Improved time parsing for packets 0x18, 0x19, 0x1A. - Improved ACK response for packets 0x01, 0x10. |
Blueberry Technology | GT06 | Added packets 0x12, 0x13 with the following parameters: - sensor_percent - temp - battery - sensor_type See parameter description. |
TOPFLYTECH Co., Limited | KnightX 100 | Improved SOS message detection. |
9 September - 13 September, 2024
Suntech | Suntech ST4305 | Added support for decoding Autosender AS0721 parameters. For conversion, enable the Autosender AS0721 by transpt option in the device configuration in the unit properties (icon ![]() |
Kingwo | Kingwo MT Series | Added command response registration. |
WanWayTech | WanWay GS10G | Added BLE sensor decoding with the following parameters: - nid - bid - mac_N - temp_{mac} - pwr_int_{mac} - battery_{mac} - alarm_{mac} - adv_{mac} - rssi_{mac} - door_{mac} - humidity_{mac} - light_{mac} See parameter description. |
BlackRock IOT | BR1201 | Added oil data parsing with the following parameters: - oil_level1 - oil_level2 See parameter description. |
Queclink Wireless Solutions | Queclink GV58LAU | Added parsing for the ign and motion_status parameters. |
Micron | Micron PT102 | Improved the time decoding functionality. |
Ruptela | Ruptela Trace5 | Added the iccid parameter registration. |
2 September - 7 September, 2024
Integrations
E3Innovations Oy | E3Blue | Integrated the E3Blue device. |
Queclink Wireless Solutions | Queclink GV55 | Fixed the issue with ign and hourmeter parameters disappearing. |
Toptraking | Toptraking G50L | Added time synchronization functionality (0x30 packet type). |
Assistant Telematics | MTL100, AVT110 | Added virtual command channel. |
Milesight | Milesight IoT | Added the tamper_status parameter. See parameter description. |
Queclink Wireless Solutions | Queclink GV56 | Added the ign parameter for ERI packet. |
26 August - 30 August, 2024
Sascar | Sascar | Improved the connection type to HTTPS protocol with TLS v1.2. |
Howen Technologies | Hero-ME41-04 | Added the following parameters: geofence_status , geofence_threshold .See parameter description. |
Teltonika | Teltonika FMC125 | Improved the decoding of Getscale GS-404 data supported via transparent channel. The parameter gs_404_card_id_dec is decoded as an unsigned integer. |
Ruptela | Ruptela Pro5 Lite | Added support for parsing text data from the SGBras keyboard. To get text data from SGBras, enable the SGBras text keyboard by transp option in the device configuration in the unit properties (icon ![]() |
Meitrack | Meitrack P99G | Added the following parameters: work_count , version , work_mode , move_state .See parameter description. |
Milesight | Milesight IoT | Added the following parameters: gpio_1 , gpio_2 , valve_1 , valve_2 , ec , moisture , pressure , geo_status , motion_status , illumination , gpio_input_1 , gpio_input_2 , gpio_input_3 , gpio_input_4 , gpio_output_1 , gpio_output_2 .See parameter description. |
Streamax Technology | Streamax X3-H0402 | Added the universal custom command (universal_command ) for changing configuration parameters. |
Micron | Micron PT102 | Improved the time decoding. |
Hikvision | Hikvision AE-DI5042-G4 | Improved the decoding of south latitude coordinates. |
19 August - 23 August, 2024
Integrations
Milesight | Milesight IoT | Integrated the Milesight IoT protocol. |
SHENZHEN THINK POWER TECHNOLOGY Co., LTD. | TL904M | Integrated the TL904M device. |
Queclink Wireless Solutions | Queclink GV350CEU | - Added parsing of +RESP:GTCLT including the following parameters: alm_mask1 , alm_mask2 , alm_mask3 , can_acc_pedal_press , can_amb_temp , can_detail_inf , can_doors , can_dtc_num , can_eng_braking_factor , can_eng_cool_temp , can_eng_rpm , can_eng_torq , can_exp_info , can_fuel_consumpt , can_fuel_level_p , can_ign_key , can_lights , can_pedal_braking_factor , can_range , can_speed , can_tacho_driv_direction , can_tacho_inf , can_tacho_motion_sign , can_tacho_ovspd , can_total_distance , can_total_fuel , cell_id , clt , dev_type , gps_acc , group_id , lac , mcc , mnc , msg_type_name , proto_ver , report , report_head .See parameter description. - Improved CAN data parsing. |
Jimi IoT (Concox) | JC450 | Improved server ACK. |
Jimi IoT (Concox) | VL101G | Improved the decoding algorithm. |
Ministry of Transport of the People’s Republic of China | JT808 | Added the following parameters: iccid , extended_alarm_status , extended_alarm_status_2 , pwr_ext , pwr_int , imei .See parameter description. |
Queclink Wireless Solutions | Queclink GV55W, Queclink GV58LAU | Improved mileage parameter decoding. |
Suntech | Suntech ST4305 | Added support for Connect-Bus via transparent channel. To get data from RST-TG100 enable the Connect-Bus by transparent option in the device configuration in the unit properties (icon ![]() |
Jimi IoT (Concox) | VL106 | Fixed parsing issues. |
Queclink Wireless Solutions | GV355CEU | Added ACK response for the TCA app upon successful authorization. |
Queclink Wireless Solutions | GV55 | Improved state parameter decoding. |
Shenzhen Cantrack Technology Co., Ltd | JT808 | Improved the send_message command type. |
12 August - 17 August, 2024
Integrations
Vacron | GMServer Gateway | Integrated the GMServer Gateway. |
ControlT | Tyrecontrol TC PRO | Integrated the Tyrecontrol TC PRO device. |
Nortac Defence | Whisper Nortac Defence | Integrated the Whisper device. |
Queclink Wireless Solutions | Queclink CV200XEU/XNA | Added parsing of GTDSA packets for device status alerts report, including the following parameters: - alm_type : Type of alarm:- 101 SIM card removed.- 102 SIM card faulty.- 103 SIM card locked by PIN.- 104 SIM card locked by PUK.- 105 SIM card normal.- 200 TF card removed.- 201 TF card cannot be accessed.- 202 TF card formatting.- 203 TF card normal.- 300 Front camera normal.- 301 Front camera faulty.- 400 Interior camera normal.- 401 Interior camera faulty.- 402 Interior camera removed. |
Jointech | Jointech JT701 | Added the query_pos command for retrieving the current device position. |
Jimi IoT (Concox) | JC400 | Added parsing of fuel sensor data with the following parameters: - fuel_sens_val_{fuel_sensor_id} Sensor value.- fuel_sens_units_{fuel_sensor_id} Sensor value unit:- 01 Height.- 02 Percentage.- 03 Voltage. |
Jimi IoT (Concox) | JC261 | Improved timestamp decoding functionality. |
TOPFLYTECH Co., Limited | Topflytech Pioneerx 100 | Improved peripheral device decoding. |
WanWayTech | WanWay GS10G | Improved the temp1wire and humidity1wire parameter decoding. |
Ruptela | Ruptela HCV5 | Added the “Cipia by transparent” checkbox to support for Cipia device by transparent channel. |
Streamax Technology | Streamax AD PLUS 2.0 | Added OBD parameters decoding functionality. |
05 August - 09 August, 2024
Galileosky | Galileosky 7x | Added registration of float user_d parameters as user_dN_fl . |
Teltonika | Teltonika FMC650 | Added ACK for the file transfer status command (CMD ID 0x0005). |
Jimi IoT (Concox) | JM-LL303, JM-LL301, Concox JM-LL01, PL200, Concox AT1 | Added the following parameters for the heartbeat (0x36) packet type: - term_info :- Bit0: 1 - Set defense (locked), 0 - Cancel defense (unlocked). - Bit1: 1 - ACC on, 0 - ACC off. - Bit2: 1 - Charging with power, 0 - Charging without power. - Bit3-Bit5: Extended bits. - Bit6: 1 - Positioned, 0 - Not positioned. - Bit7: 1 - Cut off fuel/power, 0 - Connect fuel/power. - term_defense : 1 - Set defense (locked), 0 - Cancel defense (unlocked).- term_acc : 1 - ACC on, 0 - ACC off.- term_charge : 1 - Charging with power, 0 - Charging without power.- term_pos : 1 - Positioned, 0 - Not positioned.- term_fuel : 1 - Cut off fuel/power, 0 - Connect fuel/power.- voltage_level :- 0: No power. - 1: Battery extremely low. - 2: Battery very low. - 3: Battery low. - 4: Battery medium. - 5: Battery high. - 6: Battery extremely high. - cellular_signal_strength :- 0: No signal. - 1: Extremely weak. - 2: Weak. - 3: Good. - 4: Strong. - lang_extended_port : Language/extended port status. |
ORBCOMM | Orbcomm ST 9100 | Added generate_report command. |
Suntech | ST4345, ST940, ST4340, ST3300, ST4300 | Added display of command responses. Added a property to activate this functionality. |
Sensata INSIGHTS (Xirgo Global - BCE) | BCE FMS500 StCAN | Added the Substitution coordinates functionality. |
Queclink Wireless Solutions | Queclink GB130MG | Added the following parameters for the GTALM packet type: - total_pac Total number of +RESP:GTALM messages.- curr_pac Sequence number of the current +RESP:GTALM message.- config Current configuration of the device. |
Queclink Wireless Solutions | Linkedcore, Linkedcore LV6x Series, Linkedcore LG2x Series, Linkedcore LA7x Series | Added support for ESCORT DU BLE message decoding. |
Teltonika | Teltonika FMC650 | Added rfid_value parameter. |
22 July - 25 July, 2024
Gosafe | Gosafe G16S | Added support for CAN-Logistic via transparent channel. |
Queclink Wireless Solutions | Queclink CV200XEU/XNA | Improved the video stop command. |
Queclink Wireless Solutions | Queclink GV55W | Improved the GTFRI message type decoding for the devices with version 7.00 FW and above. |
TAIGA IoT | TaigaIoT Chirpstack v4 | Improved data registration. |
Teltonika | Teltonika FMC650 | Added weight sensor support via transparent channel. |
TOPFLYTECH Co., Limited | TopflyTech TLP2-SFB | Added the following parameters for BLE fuel level sensor: - ble_sens_id BLE Fuel level sensor ID.- ble_{sensor_id}_pwr Sensor battery voltage in V.- ble_{sensor_id}_fuel_lvl Fuel level (ADC value).- ble_{sensor_id}_temp Temperature in ℃.- ble_{sensor_id}_state State (0: normal, 1: filing state, 2: leaking state).- ble_${sens_id}_rssi RSS value in dBm. |
WanWayTech | WanWay GS10G | Added the following temperature and humidity parameters: - temp_{sensor}_$i Temperature in ℃.- humidity_{sensor_id}_$i Humidity in %. |
15 July - 19 July, 2024
LEVEL Systems (Positrex) | TotalTracker | Added support for the 0x2E GREEN record type, which includes position data, information from GSM/LTE, and data from internal sensors. |
Queclink Wireless Solutions | Queclink GL320MG, Queclink GV500, Queclink GB100MG, Queclink GB130MG, Queclink GV50M, Queclink GV53MG, Queclink GV350M, Queclink GL30MG, Queclink GV57MG | Added the firmware uploading functionality from Wialon Queclink. |
Queclink Wireless Solutions | Queclink GB130MG | Added the GTBTI packet decoding with the following parameters: - bt_name Bluetooth name.- bt_state Bluetooth state (0: is not connected; 1: connected).- connected_dev_name_N The name of the connected perepheral device.- dev_mac_N The MAC address of the connected device.- dev_role_N The role type of the peripheral device (0: Master; 1: Slave).- real_tm_state Indicates whether Ghost Data is real time data or historical data read from Ghost.- ghost_battery The current volume of the backup battery as a percentage.- ghost_state Bitwise mask defining the status of the Ghost device. 0 indicates “normal status,” and 1 indicates “a specific abnormal status is detected.” For specific details of each bit, please see below.- Bit 0: Reserved. - Bit 1: GNSS fix failure. - Bit 2: Fake cell detected. - Bit 3: Low battery warning. - Bit 4: Failure to get RTC time. - Bit 5: SIM card error. - Bit 6: GSM unavailable. - Bit 7: GPRS unavailable. - Bit 8: Failure to connect to backend server. - Bit 9 – Bit 14: Reserved. - Bit 15: Communication error between MCU and BB. |
Think Power | Think Power TL-904D | Added the following parameters: - ble_mac BLE beacon MAC address.- rep_interval_pwr_on Time interval for GPS position report while ignition is on, in seconds.- rep_interval_pwr_off Time interval for GPS position report while ignition is off, in seconds.- alarm_for_heading_angle Alarm when the heading angle threshold is exceeded. Heading angle alarm state: 1 - detected 0 - not detected. |
7 July - 13 July, 2024
Integrations
iTriangle | BHARAT101PLUS-4G | Integrated the BHARAT101PLUS-4G device. |
UNIGIS | UNIGIS | Integrated the UNIGIS retranslator. |
Manufacturer | Device/Devices/Protocol | Updates |
ATrack | ATrack AK11 | Added a checkbox to hide DTC values in the chat with drivers. |
Baita Tecnologia | Baita MAC 4G | Added a command to lock/unlock the equipment. |
ERM Advanced Telematics | StarLink Tracker | Added support for the eDome LLS sensor with the following parameters: - edome_ign_on_sensor_macN MAC address of the sensor when the ignition is on.- edome_ign_on_fuel_levelN Amount of fuel (liters/percentage) when the ignition is on.- edome_ign_off_sensor_macN MAC address of the sensor when the ignition is off.- edome_ign_off_fuel_levelN Amount of fuel (liters/percentage) when the ignition is off.- edome_gps_time GPS date and time of fuel incidents(refueling/drain). |
Gosuncn | Gosuncn GD201 | Added the following parameters: - shock_value The sensor value when a shock event is detected (data_type:1293 Temperature warning, data_type:1294 Air pressure warning, data_type:1296 Ambient light detection warning).- motion_state Device is detected in/out movement state (0: Quit movement state, 1: Enter movement state).- workmode Current workmode (0x01 : Workmode 1, 0x02 : Workmode 2, 0x03 : Workmode 3). |
Concox | JM-LL301 | Added the alarm_hex parameter. |
Jimi IoT (Concox) | JM-LL303, JM-LL301, Concox JM-LL01, PL200, Concox AT1 | Added the following parameters: - pwr_ext Battery voltage.- battery Battery voltage percentage.- prod_startup_status Product startup status. |
Jimi IoT (Concox) | JM-VL502 | Updated the OBD data registration format to data_id = value , where id is OBD parameter index. |
LinkedCore | Linkedcore LA7x Series, Linkedcore LG2x Series, Linkedcore LV6x Series, Linkedcore | Improved the BLE parameters decoding algorithm. |
Ministry of Transport of the People’s Republic of China | JT808 | Added the voltage parameter for voltage value upload in V. |
Queclink Wireless Solutions | Queclink CV200XEU/XNA | Improved the playback request functionality. |
Queclink Wireless Solutions | Queclink GL320MG, Queclink GB130MG | Added FOTA (Firmware Over-The-Air) support. |
Queclink Wireless Solutions | Queclink Track | Added the custom_msg command type. |
Queclink Wireless Solutions | Queclink GV310LAU | Added device responses in the chat with drivers. |
Ruptela | Ruptela Pro5 Lite | Improved transparent data transferring. |
Ruptela | Ruptela Pro5 Lite, SGBras | Added supported for the SGBras keyboard for Ruptela Pro5 Lite. |
SEEWORLD Technology Corporation | Seeworld W18l | Added the hdop parameter. |
Streamax Technology | Streamax AD PLUS 2.0 | Added support for the Bluetooth Escort fuel sensor. |
Technotrade LLC | PTS-2 | Added the following parameters: - start_datetime Date and time of the last in-tank delivery start.- start_product_height Product height in mm.- start_water_height Water height in mm.- start_temp Temperature in degrees Celsius.- start_product_volume Product volume in liters.- start_product_tc_volume Temperature-compensated product volume in liters. |
Teltonika | Teltonika FMC650 | Added io_10611 parameter registration. |
TOPFLYTECH Co., Limited | Topflytech HeroX 100 | Added the following parameters: - drv_beh_acc Behavior type (0 : braking; 1 : accelerating, 2 : turning).- gps_data GNSS module and data state (Bit7=0 real-time data, Bit7=1 history data, Bit6=0 LBS data, Bit6=1 GNSS data, Bit5=0 GNSS working mode, Bit5=1 GNSS sleeping mode, Bit4~Bit0 Locked satellite count). |
Gurtam | WiaTag | Improved the virtual command queue. |
30 June - 6 July, 2024
Changes and improvements
Manufacturer | Device | Updates |
WanWayTech | WanWay GS10G | Added the following LLS parameters: - oil_level Height of the oil level in mm.- adc1 Analog-in value in V. |
