Working with a desktop
To add a counter or a sensor on the desktop, click on the View properties button of a required unit on the list. After clicking on the button, a unit settings dialog opens which contains a unique ID, latest coordinates received as well as custom and administrative fields. Below, you should select a counter or sensor the values of which you want to monitor. If you point to a counter/sensor, three buttons appear:
- gear-wheel (to show properties),
- chart (to show chart),
- drawing pin (to pin to the dashboard or unpin from it).
Click on the drawing pin button to place the window of a counter or a sensor on the desktop.
You can change the placement of counters/sensors by dragging them to any place on the desktop. To change window size of counter/sensor, drag its right bottom corner. If you point to a counter/sensor, several buttons for working with it appear in the window header:
- view unit properties (on the left),
- view properties (on the left),
- view chart (on the left),
- send command (on the left);
- delete from the desktop (on the right).
In addition to counters/sensors, you can place a window with the video of a unit which you monitor. To do this, click on the button in the form of a camera in the top bar and indicate the URL address of the monitored video.
