List of Units and Drivers
The left bar contains a list of available units and drivers as well as the latest chats.
There is a status icon to the right of the name of each driver and unit. If it is green, the connection is available. Besides, if there is a stable connection, the colour of the list item is bright. If the colour of the list item is bright while the status icon is inactive, this means that the device equipment supports sending virtual commands. In this case, you can send a command to such a unit even if there is no connection to it. The unit receives the command as soon as the connection is restored.
In the list, select a unit or a driver to whom you want to send a message. To find the required elements quickly, use the dynamic search at the top of the list.
