Sending commands
In the Sensolator application, you can send commands available in Wialon. To send a command, click on the button in the form of a triangle in the top string of a counter/sensor. It opens a window containing all available commands. Select the necessary command and click on the sending command button opposite to the command name. Confirm or cancel the action in the window that opens.
